Failed to retrieve schema using Chrome / Edge with Azure VPN
Ruud Evers 0 Reputation points
2025-12-08T13:35:13.4166667+00:00
We are experiencing issues querying our ADX or Azure Monitor logs using our VPN connection. The first occurred on Google Chome, but now also on Microsoft Edge. Not changes were made to the setup or configuration of the environment. Firefox still works.
Failed to retrieve schema. Please try to refresh the page.
We have experienced a connection issue while retrieving data. This is usually an indication that the network is down or a firewall or browser extension (such as an ad blocker) is mistakenly preventing access. Connection Error Request id: 15ff956b-148b-436b-a180-0114aae11fd7
Any tips on this one?
Azure VPN Gateway
Azure VPN Gateway
An Azure service that enables the connection of on-premises networks to Azure through site-to-site virtual private networks.
    2025-12-08T13:35:31.7+00:00
    It seems you are experiencing connectivity issues with Azure Monitor logs while using Google Chrome and Microsoft Edge, but Firefox works fine. Here are some troubleshooting steps you can take:
    1. Check Browser Extensions: Disable any browser extensions, especially ad blockers, as they might interfere with the connection. You can do this by opening an InPrivate window in Edge or an Incognito window in Chrome to see if the issue persists.
    2. Network Configuration: Ensure that your VPN configuration allows access to Azure services. Sometimes, VPNs can block certain traffic. You may need to check your VPN settings or consult your network administrator.
    3. Firewall Settings: Verify that your firewall is not blocking the necessary ports or addresses for Azure Monitor. Ensure that outbound port 443 is open for Azure services.
    4. DNS Issues: If you have DNS over HTTPS enabled, it might cause issues with resolving Azure endpoints. Check your browser settings to disable DNS over HTTPS temporarily.
    5. Test Other Browsers: Since Firefox works, you might want to compare the settings and extensions between Firefox and the other browsers to identify any discrepancies.
    If the problem persists after trying these steps, you may need to capture a browser trace for further analysis or consult Azure support for more detailed assistance.
  2. Vallepu Venkateswarlu 1,405 Reputation points Microsoft External Staff Moderator
    2025-12-08T13:38:45.78+00:00
    Hi @ Ruud Evers,
    It seems like you’re running into some trouble with querying your ADX or Azure Monitor logs while connected to your VPN using Chrome and Edge. Here are a few steps you can try to diagnose and potentially resolve this issue:
    1. Check your VPN Connection: Since you're able to connect and query using Firefox, the issue might be browser-specific. Ensure that your VPN is functioning properly. You can use the following Azure resources to diagnose your VPN connection:
    2. Clear Browser Cache: Sometimes cached data can cause issues. Try clearing the cache and cookies in Chrome and Edge, then see if that resolves the problem.
    3. Disable Extensions: You mentioned receiving a connection error that suggests a browser extension might be causing issues. Try disabling any extensions, particularly ad blockers or VPN-related extensions, to see if that helps.
    4. Check Browser Settings: Ensure that Chrome and Edge are set to allow connections to the Azure services you are using.
    5. Test Other Connections: Since Firefox is working, you might want to compare the network settings in Firefox with those in Chrome and Edge to see if there are any significant differences.
    6. Use Diagnostic Tools: Follow the diagnostic steps provided in the Azure documentation regarding VPN issues. You can access more expert solutions here.
    Hope this helps you out! Let me know if you have any more questions or need further assistance!
    Please Accept the answer if the information helped you. This will help us and others in the community as well.
