Front door is not working
Shobhit Joshi 0 Reputation points
2025-12-08T11:23:25.2166667+00:00
Azure Activity Log is showing Front door having issue.
  • Operation name: Health Event Activated
  • Json is showing following information
"properties": { "title": "Unavailable Backends", "details": "", "currentHealthStatus": "Unavailable", "previousHealthStatus": "Available", "type": "Downtime", "cause": "PlatformInitiated" },
Azure Front Door
Azure Front Door
An Azure service that provides a cloud content delivery network with threat protection.
  1. Vallepu Venkateswarlu 1,405 Reputation points Microsoft External Staff Moderator
    2025-12-08T11:39:30.3933333+00:00
    Hi @ Shobhit Joshi,
    Welcome to Microsoft Q&A Platform.
    The Azure Activity Log indicates that the Front Door service detected an issue. The Health Event Activated entry shows that one or more backends became unavailable. Please verify whether your backend endpoints are working directly (without Azure Front Door).
    If the backend is not reachable, the issue lies with the application, not Azure Front Door. Additionally, check Service Health to confirm whether there is any platform-related impact.
    Please review the diagnostics logs for detailed failure reasons.
    • If diagnostics logs are not enabled, go to the Azure Portal → select your AFD → Diagnostic settings → Add diagnostic setting
    I reproduced the issue in my lab and received the same error as you.
    When checking the Azure Diagnostics logs, the httpStatusCode_s value shows 405. The HTTP status code 405 – Method Not Allowed indicates that the request successfully reached the server and the resource exists, but the server rejected the HTTP method used (such as POST, PUT, or DELETE) on that endpoint.
    Please make sure to check the Azure Diagnostics for the detailed information.
    Logs details:
    As per the error: The backend is rejecting the Front Door health probe because it does NOT allow HEAD method.
    • Only configure HEAD health probes if your backend natively supports HEAD.
    • If backend does NOT support HEAD, use GET for the health probe
    • A 405 error means the backend does NOT support the probe method.
    Please feel free to ask if the provided solution does not help or if you have any additional questions.
    I hope this information helps resolve your issue. Please 210246-screenshot-2021-12-10-121802.png and “up-vote” wherever the information provided helps you, this can be beneficial to other community members.
