Issue with Right Alt + Shift Not Switching Languages Properly in Windows
Mohamed Samir Ahamed Fooda 70 Reputation points
2025-12-05T14:56:28.47+00:00
Hello,
I am experiencing an issue in Windows with the keyboard shortcut Right Alt + Shift used for switching input languages. The shortcut works only when switching from English to Arabic, but it does not work when switching from Arabic back to English. Meanwhile, the Left Alt + Shift shortcut works normally in both directions.
I have already tried the following troubleshooting steps, but the problem persists:
Adjusting the Advanced Keyboard Settings.
Removing and re-adding the input languages.
Resetting the Input Language Hotkeys.
Testing with an external keyboard – the issue remains the same.
Running settings/tools as Administrator.
Fully updating the Windows system.
Despite all of this, Right Alt + Shift still does not work when switching from Arabic to English.
Please assist in resolving this issue, as it significantly affects my workflow and typing speed. Kindly advise if there is an update or specific configuration that can fix this problem.
Thank you.
Windows for home | Windows 11 | Settings
  1. Abdelrahman Hesham 20 Reputation points
    2025-12-07T20:16:38.6933333+00:00
    Same Issue, there is no (Right Alt+Shift) option
    4 people found this answer helpful.
  2. Abdulaziz Alhurr 15 Reputation points
    2025-12-14T11:04:36.16+00:00
    Guys, I had the same issue, and it's super frustrating. Here's a fix that worked for me:
    Press Win + R, type regedit, press Enter Go to:
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout
    In the right panel:
    If Scancode Map exists, double-click it
    If not, right-click → New → Binary Value → name it Scancode Map
    In Value data, enter the following exactly
    00 00 00 00
    00 00 00 00
    02 00 00 00
    38 00 38 E0
    00 00 00 00
    It should look like this at the end:
    Click OK and restart Windows (full reboot). This should resolve the issue.
  3. PC- DABOUR 20 Reputation points
    2025-12-09T23:37:36.4233333+00:00
    As I said in this post in Arabic, this is the only solution; there is no other solution.
    https://xtls-v4.hkg1.meaqua.org/en-us
    This is the solution, my friend
    Download the program:
    AutoHotkey.exe
    Then use the script I created below. This problem literally made me unable to type properly, so I had to use an external program as a temporary workaround.
    1 - :
    #NoEnv
    SendMode Input
    *RAlt::SendInput {LAlt Down}
    *RAlt Up::SendInput {LAlt Up}
    Save this code in a file named:
    VolumeControl.ahk
    Then right-click the file and choose Run with AutoHotkey.exe
    2 - :
    shell:startup
    To run the script every time Windows starts, place a shortcut of this file in that path.
    3 people found this answer helpful.
  4. Noel Macadangdang 8,245 Reputation points Independent Advisor
    2025-12-05T15:33:53.0233333+00:00
    Hi Mohamed,
    Thank you for sharing your question. I understand how annoying this language switching thing is when you need it to work fast. Based on what Microsoft says and what others are seeing, I am here to help.
    The reason Right Alt + Shift only goes one way (English to Arabic) is a bug in recent Windows updates (like KB5070311 for Windows 11). It's not your fault. Left Alt + Shift still works because the system likes it better. Right Alt (which is like AltGr) can mess with language switching, especially after updates.
    Please follow these steps.
    Double-Check Your Shortcut Settings
    Head to Settings > Time & Language > Typing > Advanced keyboard settings.
    Click Input language hotkeys → Change Key Sequence.
    Make sure both Left and Right Alt + Shift are turned on for switching languages. Turn them back on if they aren't.
    Use a Different Shortcut for Now
    Try using Win + Spacebar to switch languages. People say it works even when Alt + Shift doesn't.
    Look for Bad Updates
    If this started after you updated Windows, get rid of the update that's causing trouble:
    Go to Settings > Windows Update > Update history > Uninstall updates.
    I hope this helps.
    Best Regards,
    Noel
  5. Mohammad Zaatra 0 Reputation points
    2025-12-14T10:07:23.39+00:00
    Same issue within my company here
    Right Alt+Shift only moves languages to the right and doesnt keep switching
    This only happened after the latest update
    Looking for a fix that i can deploy to my company desktops
