explorer.exe programs does not load --class not registered
Bea Maddox 0 Reputation points
2025-12-05T05:51:54.8366667+00:00
The explorer software corrupted and a get a bullet stating class not registered.
Microsoft Edge | Open the browser | Windows 11
    2025-12-05T05:52:04.8133333+00:00
    The "class not registered" error typically indicates that there is a problem with the registration of a component or application, which can often be caused by a corrupted file. In your case, since you mentioned that explorer.exe is not loading properly, it is likely that the issue is related to a corrupted installation of Windows or the Explorer application itself.
    To resolve this issue, you may need to reinstall Visual Studio if it is related to your development environment, or consider repairing or reinstalling Windows if the issue persists with the explorer.exe functionality.
    Additionally, if you are encountering this error while trying to connect to a remote computer, ensure that the user profile is not mandatory, as this can also cause the "class not registered" error.
  2. DaveM121 816.4K Reputation points Independent Advisor
    2025-12-05T17:14:31.7433333+00:00
    1
    Open Task Manager (Ctrl + Shift + Esc).
    Select the Processes tab.
    Find Windows Explorer in the process list, right click it and select Restart.
    Your screen will go blank for a second or two and then recover.
    Check if Explorer is then working.
    2
    If not, open the Settings App.
    Go to System - Recovery.
    Click the Reinstall Now' button in the 'Fix problems with Windows Updates' section, then wait for that process to complete.
