Frowny face box in Edge PDF reader and grey screen
Channels, Nila 0 Reputation points
2025-11-30T21:10:07.72+00:00
I was drawing on a pdf in the browser and taking screenshots as I went. Suddenly the screen went gray with a white box with a frowny face inside in the center. How do I fix it? Is there any way to get back what I was drawing? I tried to click save but nothing I click is doing anything.
Microsoft Edge | Read PDFs | Windows 11
  1. Sin-D 5,835 Reputation points Microsoft External Staff Moderator
    2025-12-01T07:37:01.6266667+00:00
    Hi Channels, Nila,
    Thanks for reaching out to Microsoft Q&A Forum. I understand you're facing the gray page with the small frowny-face box in Edge crashed. Please try:
    • Press Ctrl+P to open Print. If it opens, try “Save as PDF” to capture your current view.
    • Press Ctrl+Shift+S to trigger Web Capture (Edge’s snipping tool). If it appears, screenshot the annotated area.
    • Press Ctrl+S for Save or Ctrl+Shift+S for Save As (sometimes the shortcut still works even when clicks don’t).
    Unsaved ink annotations in Edge are held in memory until you press Save/Save As. When the renderer crashes, unsaved ink is typically lost. Edge does not auto-save ink to the original PDF unless you explicitly save. I know that’s frustrating but you can try those recommendations to prevent this happening again. Update Edge to the latest build and Disable hardware acceleration (common PDF/ink renderer fix). Also, go to edge://extensions > toggle off all extensions and retest. Finally, create a new Edge profile, open the same PDF, and test drawing. Profile corruption can cause viewer crashes.
    Also, please follow this to send feedback for Microsoft about this: Send feedback to Microsoft with the Feedback Hub app. I really sorry for your inconvenience and thanks for your understanding. For further support, please go to Contact Support
    Best regards.
