VBA help Required
Lakshmi Polisetti 20 Reputation points
2025-11-17T01:29:07.3833333+00:00
// MOLF batch helper – paste once per session, then use bookmarklet or run molfBatchFill()
(function () {
  const LS_KEY_LAST_RAW = "molf_last_raw_batch";
  const LS_KEY_PROGRESS = "molf_batch_progress";
  function installHandler() {
    // global function so bookmarklet can call it
    window.molfBatchFill = function () {
      // ----- ESC emergency stop -----
      window._molfStop = false;
      window.addEventListener(
        "keydown",
        function (e) {
          if (e.key === "Escape") {
            window._molfStop = true;
            console.warn("[MOLF] ESC pressed. Will stop after current step.");
        { once: true }
      function log(...a) {
        console.log("[MOLF]", ...a);
      function warn(...a) {
        console.warn("[MOLF]", ...a);
      // -------- get raw AR data (reuse or prompt) --------
      let raw = "";
      let storedRaw = "";
      try {
        storedRaw = localStorage.getItem(LS_KEY_LAST_RAW) || "";
      } catch (e) {
        warn("localStorage not available; resume/last-case features disabled.", e);
      if (storedRaw) {
        const reuse = window.confirm(
          "MOLF: Use last saved AR data?\n\nOK = use last batch\nCancel = paste new rows"
        if (reuse) {
          raw = storedRaw;
      if (!raw) {
        const hint =
          "Paste Excel rows (WITHOUT header).\n" +
          "Columns (TAB-separated):\n" +
          "FirstName | MiddleName | LastName | Role | JobTitle | Email | PhoneType | PhoneNumber | Country";
        const input = window.prompt(hint, storedRaw || "");
        if (!input) {
          alert("No AR data provided. Aborting.");
          return;
        raw = input.trim();
        if (!raw) {
          alert("AR data is empty after trimming. Aborting.");
          return;
        try {
          localStorage.setItem(LS_KEY_LAST_RAW, raw);
        } catch (e) {
          warn("Could not save last raw batch.", e);
      // -------- parse rows --------
      function parseRows(text) {
        const lines = text
          .split(/\r?\n/)
          .map((l) => l.trim())
          .filter((l) => l.length > 0);
        const out = [];
        lines.forEach((line, idx) => {
          const cells = line.split("\t").map((c) => c.trim());
          if (cells.length < 9) {
            warn(
              `Row ${idx + 1} has fewer than 9 columns (got ${cells.length}). Skipping.`,
              line
            return;
          const [
            firstName,
            middleName,
            lastName,
            role,
            jobTitle,
            email,
            phoneType,
            phoneNumber,
            country,
          ] = cells;
          out.push({
            index: idx + 1,
            firstName,
            middleName,
            lastName,
            role,
            jobTitle,
            email,
            phoneType,
            phoneNumber,
            country,
        return out;
      const reps = parseRows(raw);
      if (!reps.length) {
        warn("No valid AR rows parsed from input.");
        return;
      log(`Parsed ${reps.length} AR row(s).`);
      // -------- helpers --------
      function normalize(str) {
        return String(str || "")
          .toLowerCase()
          .replace(/\s+/g, "")
          .replace(/-/g, "");
      function setInputValue(el, value, label) {
        if (!el) {
          warn(`Field element not found: ${label}`);
          return;
        if (window._molfStop) return;
        el.focus();
        el.value = value ?? "";
        el.dispatchEvent(new Event("input", { bubbles: true }));
        el.dispatchEvent(new Event("change", { bubbles: true }));
        el.blur();
        log(`${label} filled:`, value);
      function setSelectByTextLoose(el, text, label) {
        if (!el) {
          warn(`Select element not found: ${label}`);
          return;
        if (!text) {
          warn(`${label}: value empty; leaving as is.`);
          return;
        const targetNorm = normalize(text);
        let found = false;
        for (const opt of el.options) {
          if (normalize(opt.text) === targetNorm) {
            el.value = opt.value;
            log(`${label} selected:`, opt.text);
            found = true;
            break;
        if (!found) {
          warn(`${label}: option not found for "${text}". Please select manually.`);
      // -------- identify WCIS ID for batch key --------
      const wcisEl =
        document.getElementById("WcisId") ||
        document.querySelector("input[name='WcisId']");
      const wcisId = wcisEl ? String(wcisEl.value || "").trim() : "";
      function simpleHash(str) {
        let h = 0,
          i,
          chr;
        if (!str) return "0";
        for (i = 0; i < str.length; i++) {
          chr = str.charCodeAt(i);
          h = ((h << 5) - h) + chr;
          h |= 0;
        return String(h);
      const batchKey = `wcis:${wcisId || "none"}|hash:${simpleHash(raw)}`;
      // -------- resume progress --------
      let startIndex = 0;
      try {
        const rawProg = localStorage.getItem(LS_KEY_PROGRESS);
        if (rawProg) {
          const prog = JSON.parse(rawProg);
          if (
            prog &&
            prog.batchKey === batchKey &&
            prog.nextIndex != null &&
            prog.nextIndex < reps.length
            const resume = window.confirm(
              `MOLF: Detected unfinished batch for WCIS ${wcisId || "(unknown)"}.\n\n` +
                `Last completed AR index: ${prog.nextIndex} of ${reps.length}.\n` +
                `OK = resume from AR #${prog.nextIndex + 1}\nCancel = restart from AR #1`
            startIndex = resume ? prog.nextIndex : 0;
      } catch (e) {
        warn("Could not read/parse progress from localStorage.", e);
      if (startIndex >= reps.length) {
        log("All ARs in this batch appear processed already.");
        return;
      const ar = reps[startIndex];
      log(`Processing AR #${startIndex + 1} of ${reps.length}:`, ar);
      // -------- mandatory-field check (MiddleName is optional) --------
      function isEmpty(v) {
        return v == null || String(v).trim() === "";
      const missing = [];
      if (isEmpty(ar.firstName)) missing.push("FirstName");
      if (isEmpty(ar.lastName)) missing.push("LastName");
      if (isEmpty(ar.role)) missing.push("Role");
      if (isEmpty(ar.jobTitle)) missing.push("JobTitle");
      if (isEmpty(ar.email)) missing.push("Email");
      if (isEmpty(ar.phoneType)) missing.push("PhoneType");
      if (isEmpty(ar.phoneNumber)) missing.push("PhoneNumber");
      if (isEmpty(ar.country)) missing.push("Country");
      if (missing.length > 0) {
        const nameLabel = `${ar.firstName || "(no first)"} ${
          ar.lastName || "(no last)"
        }`.trim();
        warn(
          `Skipping AR #${startIndex + 1} (${nameLabel}) – missing: ${missing.join(
        try {
            LS_KEY_PROGRESS,
            JSON.stringify({ batchKey, nextIndex: startIndex + 1 })
        } catch (e) {
          warn("Failed to save progress after skip.", e);
        alert(
          `Skipped AR #${startIndex + 1} (${nameLabel}).\n\n` +
            `Missing fields: ${missing.join(", ")}.\n` +
            `Run MOLF again to continue with the next AR.`
        return;
      if (window._molfStop) {
        warn("Stopped before filling because ESC was pressed.");
        return;
      // -------- map DOM fields --------
      const firstNameEl = document.getElementById("FirstName");
      const middleNameEl = document.getElementById("MiddleName");
      const lastNameEl = document.getElementById("LastName");
      const roleSel = document.getElementById("RoleType");
      const jobTitleEl = document.getElementById("JobTitle");
      const emailEl = document.getElementById("EmailAddress");
      const phoneTypeSel = document.getElementById("PhoneNumberType");
      const phoneEl =
        document.getElementById("PhoneNumber") ||
        document.querySelector('input[name="PhoneNumber"]');
      const countrySel =
        document.getElementById("Country") ||
        document.querySelector('select[name="Country"]');
      if (!firstNameEl || !lastNameEl) {
        warn(
          "FirstName or LastName fields not found. Are you on the Create Authorized Contact form?"
        return;
      // -------- fill fields --------
      setInputValue(firstNameEl, ar.firstName, "First Name");
      setInputValue(middleNameEl, ar.middleName, "Middle Name"); // optional
      setInputValue(lastNameEl, ar.lastName, "Last Name");
      setSelectByTextLoose(roleSel, ar.role, "Role");
      setInputValue(jobTitleEl, ar.jobTitle, "Job Title");
      setInputValue(emailEl, ar.email, "Email");
      setSelectByTextLoose(phoneTypeSel, ar.phoneType, "Phone# Type");
      setInputValue(phoneEl, ar.phoneNumber, "Phone#");
      setSelectByTextLoose(countrySel, ar.country, "Country");
        warn("Stopped after filling because ESC was pressed (no submit).");
        return;
      // -------- save nextIndex BEFORE clicking submit --------
      const isLast = startIndex === reps.length - 1;
      try {
          LS_KEY_PROGRESS,
      } catch (e) {
        warn("Failed to save progress before submit.", e);
      // -------- click the right button --------
      const btnSubmit = document.querySelector('button[name="Create"]');
      const btnAddAnother = document.querySelector('button[name="SaveAddAnother"]');
      if (isLast) {
        log("This is the LAST AR in batch → clicking Submit.");
        if (btnSubmit) btnSubmit.click();
        else warn("Submit button (name=Create) not found. Click it manually.");
      } else {
        log("More ARs remaining → clicking Submit & Create Another.");
        if (btnAddAnother) btnAddAnother.click();
        else warn(
          "Submit & Create Another (name=SaveAddAnother) not found. Click it manually."
      log(
        `Done processing AR #${startIndex + 1} of ${reps.length}. ` +
          "After page reload, run molfBatchFill again (or click the bookmarklet)."
    }; // end molfBatchFill
    console.log(
      "[MOLF] molfBatchFill() installed. Call molfBatchFill() or use the bookmarklet to run."
  installHandler();
  // auto-run once when you first paste it
  if (window.molfBatchFill) {
    window.molfBatchFill();
Microsoft 365 and Office | Excel | For home | Android
    2025-11-17T01:29:33.34+00:00
    The provided VBA code is designed to implement soft-lock logic and manage task IDs within an Excel worksheet. It includes several key functions and event handlers:
    1. IsInRange: Checks if a given range intersects with another range.
    2. TopLeftCell: Returns the top-left cell of a specified range, accounting for merged cells.
    3. IsProtectedEdit: Determines if an edit should be soft-locked based on the target range.
    4. NormalizeCategory: Normalizes a category string by removing spaces and special characters.
    5. CategoryNeedsID and IsBreakOrNoInv: Determine if a category requires an ID or falls under specific conditions.
    6. Worksheet_SelectionChange: Captures the original value of a cell when the selection changes and tracks changes in specific cells.
    7. Worksheet_Change: Handles changes in specific cells (I28 and I29) to manage task IDs and start timers based on category conditions.
    The code effectively manages user interactions with the worksheet, ensuring that edits are controlled and that task IDs are handled according to the specified business logic. It also includes error handling to maintain application stability during operations.
    If you need further assistance with specific parts of the code or additional functionalities, feel free to ask!
