Virtual machines or virtual machine scale sets are running on images that will be deprecated soon
Kishore Loaknath 0 Reputation points
2025-10-07T16:25:33.5433333+00:00
Got the email below on how to upgrade the image without losing data or migrate to new VM.
|Your workloads are running on images
You’re receiving this email because you have virtual
machine and/or virtual machine scale set deployments that are running on
images scheduled for deprecation.
One or more plans within the offer Windows-10 from the
publisher, MicrosoftWindowsDesktop, have been
scheduled for deprecation. You currently have workloads that are running
on images within these plans.
Impact
· Following the
scheduled deprecation date, you won’t be able to deploy any new virtual
machines (VM) or virtual machine scale set (VMSS) instances using the
images listed below.
· Your active VM
instances won’t be affected following the deprecation date.
· Your existing VMSS deployments
will continue to be operational but can’t be scaled out following
deprecation.
Plans scheduled for deprecation
Publisher
Offer
Plan
Deprecation date (UTC)
Recommended alternative
Windows-10
win10-21h2-pro-g2
October 22,
2025
No alternative
option provided by Publisher. Please test and use some other suitable
alternative from Marketplace
For more details on the next steps after your image is
scheduled for deprecation, visit https://aka.ms/DeprecatedImagesFAQ.
If you have previously updated your Virtual Machine or
Virtual machine Scale Sets to a newer version via Azure Update Manager or
other means, kindly ignore this notification.
For more details on the next steps after your image is scheduled for deprecation, visit https://aka.ms/DeprecatedImagesFAQ. If you have previously updated your Virtual Machine or Virtual machine Scale Sets to a newer version via Azure Update Manager or other means, kindly ignore this notification.|
Azure Virtual Machine Scale Sets
Azure compute resources that are used to create and manage groups of heterogeneous load-balanced virtual machines.
  1. Jilakara Hemalatha 6,200 Reputation points Microsoft External Staff Moderator
    2025-10-07T22:42:57.4066667+00:00
    Hi Kishore Loaknath,
    Thank you for your question about migrating workloads from a deprecated image for virtual machines (VMs) or virtual machine scale sets (VMSS). Below is detailed guidance to help you upgrade your image or migrate to a new VM without losing data, along with best practices and additional resources.
    NOTE:
    1. After the scheduled deprecation date, you cannot deploy new VMs or VMSS instances using the deprecated image.
    2. Existing VMs will continue to run without interruption.
    3. Existing VMSS deployments will remain operational but cannot be scaled out (i.e., you cannot add new instances) after deprecation.
    Reference: https://xtls-v4.hkg1.meaqua.org/en-us/azure/virtual-machines/deprecated-images
    Recommendation:
    • The recommended approach to upgrade your VM or VMSS is to create new VMs or scale sets with the supported OS/image version you intend to use and then migrate your workloads.
    • For minimal disruption, separate your data from the OS disk by using additional data disks. This enables you to move or reattach data disks independent of the OS during migration.
    • For VMSS, Enable Automatic OS Image Upgrades to apply the latest supported image automatically.
    Please find below documentations for more details:
    How do I migrate my workloads to another image?
    https://xtls-v4.hkg1.meaqua.org/en-us/azure/virtual-machine-scale-sets/virtual-machine-scale-sets-upgrade-scale-set
    https://xtls-v4.hkg1.meaqua.org/en-us/azure/virtual-machine-scale-sets/virtual-machine-scale-sets-automatic-upgrade
    Hope this helps! please let me know if you have any queries.
