How to fix "x32dbg.exe system error" to fix missing x32bridge.dll message on startup of my laptop?
M G 0 Reputation points
2025-07-24T06:31:37.62+00:00
Can you please help me fix this annoying message on startup "x32dbg.exe system error" which says there is a missing x32bridge.dll file on my laptop? I am not sure what it means but my system is playing up.
I have followed the support page and run DISM and the system file checker and restarted and no change, the error message still comes up. I do not get anything when i follow the instructions to see the sfcdetails.txt file.
Any help please?
Surface | Surface Book | Performance and maintenance
  1. Rez 13,000 Reputation points Independent Advisor
    2025-07-24T15:22:22.4966667+00:00
    Hi there,
    Thanks for reaching out to the Microsoft Community. I see that you’re having this persistent issue with a startup error related to x32dbg.exe, which is a debugging tool often used for reverse engineering or low-level debugging. The error message about x32bridge.dll being missing suggests that either:
    • The application was partially uninstalled, or
    It was moved or deleted improperly, leaving behind startup entries or scheduled tasks.
    Here's how to fix it:
    1. Check Startup Entries
    This error often comes from a leftover startup entry trying to launch x32dbg.exe.
    Press Ctrl + Shift + Esc to open Task Manager
    Go to the Startup tab.
    Look for anything related to x32dbg or unknown entries.
    Right-click > Disable anything suspicious.
    Alternatively, use Autoruns from Microsoft Sysinternals:
    Download from: https://xtls-v4.hkg1.meaqua.org/en-us/sysinternals/downloads/autoruns
    Run it as Administrator.
    Search for x32dbg or x32bridge.dll.
    Uncheck or delete any entries pointing to missing files.
    2. Remove Broken Scheduled Tasks
    Sometimes, a scheduled task tries to run x32dbg.exe.
    Open Task Scheduler (taskschd.msc).
    Look under Task Scheduler Library for anything related to x32dbg.
    If found, delete the task.
    3. Clean Up the Registry (Optional but Advanced)
    If you're comfortable:
    Press Win + R, type regedit, and press Enter.
    Navigate to:
    HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run
    HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run
    Look for entries referencing x32dbg.exe or x32bridge.dll.
    Back up the registry, then delete the offending entries.
    4. Fully Reinstall or Remove x32dbg
    If you still need x32dbg:
    Reinstall it from the official GitHub page.
    If you don’t need it:
    Delete its folder (usually in C:\x32dbg or similar).
    Then clean up startup entries as above.
    Let me know if you need more information or help by replying to this thread.
    Cheers,
    Restee M.
    Microsoft Community Contributor
